Home > Wheels & Tyres > Any reason why not? |
No, there's no reason not to do this. It's a very common mod. Darren
15th Jun 2017 8:38pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
Adding 30mm spacers vastly improves turning circle, highly recommend. James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
15th Jun 2017 8:58pm |
Timcat Member Since: 20 Jul 2016 Location: Tanzania at the moment Posts: 1005 |
Many thanks for the replys, are there any guidelines on adjusting the stops? Is it just adjust to give a certain amount of clearance or do you have to take into account that it's going to be used off road & give it a bit more?
15th Jun 2017 10:33pm |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
Easy to do just adjust lock to lock and make sure that tyres don't rub the inner arches.
Make sure you buy hub centric spacers |
15th Jun 2017 10:42pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16858 |
I set mine so that I can just slip a finger between the tyre and radius rod on full lock with the vehicle on level ground. This, I find, means that the tyre seldom rubs on the road but can at certain axle articulations off road, which doesn't bother me.
Every year the MOT tester tells me that the tyres on full lock are incredibly close to the radius rod and would fail if they touched, so I reckon I have got it as tight as practicable! I always make sure that there are no witness marks before the MOT, of course. |
15th Jun 2017 10:57pm |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
I used to trial my 90 and 110 and deliberately had the lock stops set so that the tyres contacted the radius arms - that way you know you have the absolute max lock. Spacers and non-standard offset rims aren't permitted. I was lucky that the mot tester was in a part of Somerset that was rich in ARC members so they never failed.
16th Jun 2017 1:39am |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 |
After fitting spacers I marked a corner on each "stop" with white "Cutex" - and then adjusted 2.5 turns.
16th Jun 2017 6:03am |
I have a set of Terrafirma hub centric spacers for sale
Also as a mechanical numpty has anyone got a photo that they can put a big arrow on pointing the the steer stops? All this talk of radius arms goes over my head... TIA James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
16th Jun 2017 7:04am |
proloForêt Member Since: 16 Mar 2017 Location: Montereau Posts: 248 |
look at this page for full mode how to do and pictures to do stops: http://defender90xs.blogspot.fr/2013/11/st...tment.html |
16th Jun 2017 9:16am |
proloForêt that's perfect! Thank you very much James
16th Jun 2017 9:56am |
See PM |
18th Jun 2017 8:42am |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1185 |
Bolt near the swivel
Click image to enlarge Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
18th Jun 2017 8:51am |
Well all done, what a difference! Makes a massive improvement almost bus like, stopped in London the weekend so had chance to see how it got on with the tight spaces and very impressed.
10th Jul 2017 7:21pm |
