Home > Td5 > Added bonnet struts with home made brackets |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4789 |
Nice work, will add that to my list of things to do 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
10th Jun 2017 5:27pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
Is that some sort of sound deadening spray on the underside of your bonnet, and if so does it make a difference. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
http://www.youtube.com/user/conwy1 |
10th Jun 2017 6:18pm |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
Ha! i spotted that too and was about to ask the same question
10th Jun 2017 6:34pm |
I see your original bonnet stay is still fitted. Will that be coming off or do you foresee circumstances where you will still use it?
10th Jun 2017 6:36pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 898 |
I LINEX'd it.. very helpful to stop innocuous dents from forming on the bonnet. As for sound, no real noticeability there. The rubber seal on the bonnet edge did a LOT to reduce any noise from the engine bay. No leaking sound from around the edges, also the Td5 is pretty quiet compared to Tdi's and NA Diesels. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
10th Jun 2017 7:27pm |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 305 |
Nice!
Princess Auto struts? I've just been doing the install of my Webasto under the hood on my 2003 and see you have one installed. Did you bother with the one way valve in the 18mm inlet hose for when the Webasto is not running? Also, did you find any difference in heater airflow with the snow cowl installed during the winter? Cheers Patrick |
11th Jun 2017 4:47pm |
No difference with the airflow and snow cowl in place has been noticed . I also have the Landreziegr digital fan speed control installed which I did notice increased full speed quite a bit. As for the Wabasto it came from the factory with it intsalled so cannot comment with great alacrity.
Princess Auto is a national store for farmers, hydraulic stuff, surplus and all kinds of great off road and recovery gear at great prices. Also tons of trailer and auto electric parts, welding fabrication and tools. https://www.princessauto.com/en/ 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
11th Jun 2017 5:22pm |
