Home > Td5 > Throttle position setting. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2049 |
Your MAF sensor could be dead and causing these issues, as could a boost leak.
I would check your MAF - If you have a Nanocom/Hawkeye air flow should read about 58 - 60 if its anything else your MAF is dead. Only replace with genuine, VDO or Siemens the rest arnt worth it. I would also check any hoses for de-lamination, splits and cracks. I'd also check your intercooler isnt split. You should be able to tell either if there is oil blow by around a hose/IC Could also be the MAP sensor. Or it could be the hi-low switch swapping you between high range and low range maps... Tbh im not 100% the throttle pot is adjustable. Ideally you need to get it plugged into some diagnostics to check |
8th Jun 2017 10:55am |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 890 |
What ^^^^Bankz ^^^^ said, get it plugged in and have the codes read... start there... Don't screw around with anything till you do. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
8th Jun 2017 3:20pm |
As you have a 2001 model you probably have the 2 potentiometer throttle instead off the 3 pot later models.
If one off the potentiometers gets a dead spot your ecu get's confused that is why the 3 pot throttle were introduced. If you don't have a Nanocom or something like that you can check the working with a voltmeter. I don't have my Rave disc with me so I have to do it by memory. On your throttle you will have the following wires: Supply voltage off about 4.5 V throttle position voltage 0-4.5V and one 4.5-0V And you might have a earth cable The 0-4.5V and the 4.5-0V should change smoothly if you slowly press you accelarator. If one off both is not smooth that might be the problem. The easiest way to measure the voltage is on the ecu. But you will have to find the connectors. On the newer modells they are Black plug: 12,14,20,26,36. They could be the same on the old model ( but 1 less) but I am not sure about that. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
8th Jun 2017 9:03pm |
portal pat Member Since: 05 Jan 2015 Location: South. Very south. Posts: 32 |
Thank you all for your input. Went to our local LR guru and hooked ECU to diagnostics. Throttle Position Sensor was on#2 instead of #3! Surging gone and motor feels generally more smooth and tractable. Cheers. Nothing suggests poor workmanship like wrinkles in the duct tape.
9th Jun 2017 2:35am |
