Home > Td5 > What causes oil to get dirty?
BCdefender
Canada 1999 Defender 110 Td5 CSW Orkney Grey
Sort of a funny question I know But I changed my oil about 6 months ago and a month ago when I checked it the oil was pristine. Now it has become noticeably dirtier. Could this be from driving down dusty logging roads? Its the only thing I've changed in terms of driving habits.
Thanks! 1999 Defender 110
2003 P38
2007 RR SC
"And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it."
My build thread: http://www.defender2.net/forum/topic47750.html
Post #628347 2nd Jun 2017 5:23am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
As the oil travels around the engine in picks up microscopic metal partials, carbon deposits, old oil that is impossible to remove all traces of on an oil change, as it is constantly heating up and cooling down all these factors change the colour and consistency. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #628348 2nd Jun 2017 5:45am
LR90XS2011
if you have a good air filter the dusty roads make no difference , the black in diesel engine oil is just the soot from the combustion process, oil generally stays cleaner in petrol engines as there is less soot. lots of short journeys or idling will increase soot but dont worry dirty oil on diesels is normal. one other thing that can affect is is the detergent level of the oil, modern oils have high detergent levels to keep the engine clean hence they get dirty quickly but this is AOK as the soot in the oil is no biggie DEFENDER 90 TDCI XS,
Post #628357 2nd Jun 2017 6:27am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
New oil in my 90 td5 is dark after one drive. It looks a lot worse after one drive then the same oil after 24000 km in my D3 V8. The V8 oil looks almost new. I sometime ask myself if the V8 really needs an oil change and sometimes I think should I flush the td5 with the old oil of the V8? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #628606 3rd Jun 2017 3:03am
cobra_mark
United Kingdom 2000 Defender 90 300 Tdi SW Barolo Black
Had a sump change after my rebuild as the sump thread had been stripped, oil is still very clean.
Post #628640 3rd Jun 2017 9:50am
Clive
It does help to try to ensure as much as possible of the old oil is drained when doing an oil change, I always take mine out for a drive beforehand to get everything up to working temperature and to make sure any particulate matter in the oil is in suspension rather than collected at the bottom of the sump. I then put the front on ramps, partly to improve clearance, but also the drain plug is at the back so it naturally drains better, plus any oil in the galleries in the head and block will drain more thoroughly,
Any residual oil left in the engine after a change will very quickly discolour the new oil but it's not really too detrimental, diesels are a dirty engine anyway and as LR90XS2011 says it's mainly soot from the combustion blow past, a perfectly natural occurrence.
This is mine after two days and about 50 miles
Post #628659 3rd Jun 2017 12:52pm
