Home > Expedition & Overland > Foxwing
chris d3
England 2011 Defender 110 Puma 2.2 USW Stornoway Grey
Foxwing
Has anyone mounted a Foxwing to a Patriot rack? Any chance of some pictures how you've mounted please
Post #628320 1st Jun 2017 9:51pm
leeds
Chris, have you got the luggage rail fitted?
The Foxwing has 2 T channels running down the back of the main plate. A 8mm hex bolt head will slide down the T channel.
If you have luggage rail fitted get some 6 x 40-50mm (say) plate and drill 2 x 8.5mm holes at 100mm spacing. Long 8mm bolts and clamp the bottom and luggage rail between Foxwing and 6mm plate
No luggage rail? Use the 2 countersunk holes where the luggage rail uprights attach. Get some 6mm plate use a countersunk bolt to attach 6mm plate to bottom rail through one hole. 8mm hex head bolt through other hole. Drill 8mm clearance hole 100mm up plate. You need to use a 10mm nut or lots of spacers for top bolt.
Hope that makes sense, give me a ring on 07929 604668 if you want a clearer explanation.
Brendan
Post #628333 1st Jun 2017 10:48pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
[img]https://www.defender2.net/gallery/albums/userpics/14155/normal_IMG_20170602_055630.jpg[/img
Like this Thumbs Up
Post #628352 2nd Jun 2017 5:58am
williamthedog
I'll try again
Post #628353 2nd Jun 2017 6:00am
chris d3
Cheers lads
Post #628801 3rd Jun 2017 11:39pm
