Home > Wheels & Tyres > Under pressure.. |
30 and 48 worked for me for a loaded 110. Darren
28th May 2017 11:24am |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 570 |
I run my 90 fully loaded roof tent Foxwing & all camping associated stuff.
40psi road,usualy for drive to destination. 18psi to 25psi for off road depending on how rocky loose or muddy conditions are. Tyres are BFG M/T 285/70/16 I find these pressures work well for me. Marc |
28th May 2017 11:37am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19560 |
32 F 34 R for me in my 90 with 255/85 KM2's.
Varies between 110 and a 90 due to weight, 110's normally require higher on the rear due to length and weight handling. This suite me for what I do, probably another couple of psi on thecrear if towing very heavy but I don't. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
28th May 2017 11:41am |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
Rough rule I use for highway initial set up is to inflate until the side wall has stood up( not bagged out) and add 10psi.
I then look for a 3-5psi increase after an hour of driving, less is over inflated/ more is to low. (From a quick google search)...http://www.aawen4x4.com.au/ For high speed dirt roads I deflate until I see the side wall start to bag out and go 5psi more. For harder tracks(rocks etc) I go another 5psi again but drive to suit. For reference only I run at close to full weight on holidays running KM 2 mud tyres while towing 1600kgs of bed on wheels with our 110. Highway, 44 front, 55->60 rear, 44 TVan. Dirt (80km/h), 34 front, 42>50 rear, 35 TVan. Rock crawling tracks 28 front, 30 rear not towing or 36, 30 TVan. All of this I monitor with an onboard TPMS with the sensors strapped inside each wheel including spares. Cheers, Kyle. |
28th May 2017 11:44am |
