Home > Maintenance & Modifications > Boost alloys paint |
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 |
Sparkle Silver.
24th May 2017 6:52pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19568 |
Thank you 👌🏻👍🏻 Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
24th May 2017 7:38pm |
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 148 |
The code is MNH, I too have the same problem with the paint lifting where weights have been hammered on. Any tips on repairing would be great, which primer is best?
Click image to enlarge |
24th May 2017 9:01pm |
I would have thought Acid Etch primer being alloy, a spot repair won't be absolutely flawless but barely noticeable compared to the damage.
I think and often have heard the paint is very thin, the clear coat doesn't seem over thick either. My latest weights have been put on the inside of my Boosts which makes me wonder why on earth they were put on the outside anyway. They look brilliant completely without on the outside. Thank you for the paint code as well. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
24th May 2017 10:54pm |
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 |
They don't always balance correctly on the inside, I've seen some wheels with stick on weights stacked three high. Also although you don't notice you would be shocked at the amount of corrosion on the inside of ally wheels as paint is virtually nill on the inside.
24th May 2017 11:02pm |
They aren't stick on they are clamp on. They won't be going anywhere. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
24th May 2017 11:08pm |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
I too have this issue picking up a set of 5 X boost alloys cleaned um up , a few marks, scuffs and curbing etc. Took outside weights off with some difficulty only to find the paint missing underneath , not happy as I could live with the rest. I was looking into try and touch them up etc but now thinking I'll get my local body shop to re paint them for approx 30 a wheel for the sake of hassle and expense. I was hoping to get them balanced with weights on inside only or magnetic ones on inside or something..
5th Sep 2017 8:36pm |
