Home > Td5 > kangarooing TD5 |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1168 |
Hi Martin
I'm interested to see what the consensus is here..... I have just bought my first Td5 and experience the same , though only sometimes when pulling away in first then from first to second gear. I have been told that it could very well be the dual mass flywheel And these used to shatter and were replaced under warranty when the Vehicles were not far from old. It could be this or a sloppy clutch So , I look forward to hearing what is said here G My confidence has been writing cheques that my abilities can't cash for years. |
18th May 2017 10:24pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2065 |
Could be the MAF.
Check for oil in the redplug and clean the MAP |
18th May 2017 10:33pm |
Throttle pedal on the way out? Only a twin track as it's 1999. Worth getting it plugged into a nanocom and reading live data perhaps? 2002 90 Td5 Station Wagon
18th May 2017 10:35pm |
Grafts ,
Mine is a 2002 , same idea ?? Plug into the Nanocom? Sorry to piggyback the op's thread G My confidence has been writing cheques that my abilities can't cash for years. |
18th May 2017 10:50pm |
I think 2002 (mine included) onwards have the NNN type ECU and therefore a three track throttle pedal. But this only makes them less prone to failure and not immune to it. I think nanocom gives you throttle pedal data live 2002 90 Td5 Station Wagon
18th May 2017 10:55pm |
Thanks Grafty
Time to buy beer and pick the brains of the techs at work My confidence has been writing cheques that my abilities can't cash for years. |
18th May 2017 10:58pm |
18th May 2017 11:04pm |
martindavis Member Since: 10 Nov 2015 Location: Cumbria Posts: 20 |
Hi i fitted a solid fly wheel as the duel mass had failed I wouldn't think its the clutch as it its still the same now as before I have put a multi meter on the m a f sensor and is reading as it should its on an m s b ecu I will have to track down a throttle peddle and give it a try as I don't have a computer to plug in thank you for your reply's I will up date if I find anything
18th May 2017 11:15pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 572 |
Try to just unplug the MAF, and clean the MAP and check air filter and air pipes for damage/blockage. This is fast and simple.
Than try to find someone with diagnostics (nanocom). "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
19th May 2017 6:51am |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 |
Mine did the aussie thing every now and then. But then it stopped for ages and ages. Then one day I was checking my fluid levels and noticed that I never plugged the lunch switch back in. So, I did...then started noticing it again.
So now it is unplugged. TD5 Defender 90 Discovery 3 HSE |
19th May 2017 8:50am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16858 |
You gotta love predictive text/spell checkers! |
19th May 2017 9:08am |
Ha. Damn autocorrect... TD5 Defender 90
Discovery 3 HSE |
19th May 2017 9:28am |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
so what switch was it huff? 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
23rd May 2017 12:55am |
Hi I have Tryed unplugging the clutch switch on the master cylinder and still the same
23rd May 2017 9:00am |
