Home > Td5 > kangarooing TD5 |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2049 |
Could be a boost leak.
23rd May 2017 9:57am |
martindavis Member Since: 10 Nov 2015 Location: Cumbria Posts: 20 |
I will dubble check everything and maby try a fresh ecu
23rd May 2017 6:39pm |
Split intercooler or hoses, or oil in red ecu plug. Ray
23rd May 2017 7:29pm |
Could be a faulty high low switch and the ecu is switching between throttle maps 2002 90 Td5 Station Wagon
23rd May 2017 9:46pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5725 |
If switch goes faulty which way does it default to? High or low? 1999 Defender TD5 110
24th May 2017 5:07am |
If have thought high to make it reasonably driveable. The throttle map in low range is incredibly soft 2002 90 Td5 Station Wagon
24th May 2017 10:24pm |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1168 |
The cause of my judder has been diagnosed......
I'm not heavy enough on the gas when pulling away an a broken engine mount:bush is causing vibration Will get that sorted next week hopefully. Oh , an a worn a frame bushing clunking G My confidence has been writing cheques that my abilities can't cash for years. |
26th May 2017 7:10pm |
Hi all I unplugged the hi/ low switch and have been trying it over a couple of weeks and seems to have stoped kangarooing I will have to give a new switch a try and see how that goes fingers crossed will update when the I have fitted the new switch. Thanks all for the advice
19th Jun 2017 10:36pm |
