Home > Technical > Hazards lights/ indicator issue |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 |
Morning mate I'm no expert ..I have had occasional issues check the wire connectors at the rear of the hazard switch are fully pushed home they do have a habit of working lose.
Terry |
15th May 2017 8:19am |
lb73 Member Since: 27 May 2016 Location: North Wales Posts: 287 |
Cheers Terry, will give that a look later, plus if it needs replacing I think may have a spare switch floating round in the garage. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
15th May 2017 10:11am |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4932 |
id say its the hazard switch, be very wary of cheep replacement ones, I thought was a lucas part and it wasn't, after it started causing all 4 lights to flash if I engaged left or right with the stalk. I did have a bit of a fiddle with the socket at the back of it, which corrected it, but I found a proper lucas part and swopped if over. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
17th May 2017 4:57pm |
Thanks Procta will give the hazard switch a closer look, found some useful info via this link as well : https://forums.lr4x4.com/topic/25376-hazar...diagnosis/ 1999 300TDI 110 CSW BMW 3.0
17th May 2017 8:50pm |
Well it was the the hazard switch, just fitted a new Lucas one and everything works as it should. Thanks again. 1999 300TDI 110 CSW BMW 3.0 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
19th May 2017 4:29pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
Deleted as Posted in wrong thread For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
http://www.youtube.com/user/conwy1 |
19th May 2017 4:42pm |
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 297 |
Superb timing for me. The link is fantastic help!
21st May 2017 6:41am |
