Home > Off Topic > My RRC project |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4789 |
Looking good and some great work you have done George 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
19th Jun 2018 8:11pm |
and your next project |
19th Jun 2018 8:29pm |
Defender next, investigate the head/head gasket issue then who knows? 2002 90 Td5 Station Wagon
19th Jun 2018 8:45pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10471 |
I know what project will be next
Great news grafty on the pass before you burn some more petrol, make sure the tank is full 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
19th Jun 2018 9:58pm |
Tank filled on the way to the MOT as the light was on
Done about 10 miles so far. All seems ok, a little bit rough under load about 2,000rpm. It has a new coil and rotor arm. Dizzy cap is very good so going to pop a set of plugs and some magnecore leads. Who knows, if I fall in love with the V8 I might have to put one into the defender 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
19th Jun 2018 10:05pm |
And a picture to prove I made it to the village
Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
19th Jun 2018 10:24pm |
You do realise that you will have to change that tail pipe if your going to take any more rear pic's 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
19th Jun 2018 10:34pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4932 |
Sounds like it could do with a good run really, My rover really did run well after a good long drive, just to burn all the crap through, and if this has been sitting and having practically no fuel in, then it will be running a little rough. I ran magnecore leads on my rover, you can get two blue and red. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
20th Jun 2018 7:55am |
I've just ordered some Magnecor leads from RPI. Blue ones unfortunately which isn't really my style, I'd have preferred black but they aren't available
Going to pop in a set of BPR6ES plugs, it has BPR7CS plugs in at the moment which are a grade hotter but with a different tip. I guess maybe to help with combustion on lpg but going back to the correct ones for the time being 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
20th Jun 2018 8:17am |
From memory the Red ones were the best for performance, I know Magnecore leads are not cheap at the best of times. But they have a life time guarantee. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
20th Jun 2018 7:12pm |
It could do with a twin pipe, as his tail pipe looks like it belongs on a boy racers car Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
20th Jun 2018 7:13pm |
It's really not that bad! Haha it will be changed though, all in good time
40 trouble free miles so far 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
20th Jun 2018 11:03pm |
How much did the restore cost all total? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
21st Jun 2018 7:26pm |
Still under £1500 I think so far. Have budgeted for a fair bit more than that but once the cosmetic bits start then I'm sure the price will start to rise!
Fitted the new Magnecor leads and new dizzy cap and rotor arm today so need to go on a bit of a drive and see if it is any better 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
21st Jun 2018 9:30pm |
