Home > Off Topic > My RRC project |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10502 |
1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
4th Jan 2018 12:06am |
Work is starting on the body imminently, got some bits arriving for it very soon 2002 90 Td5 Station Wagon
5th Jan 2018 2:33pm |
Darrens110 Member Since: 04 Jan 2018 Location: Staffordshire Posts: 68 |
Now that's a proper restoration, rather you than me!!
5th Jan 2018 2:59pm |
Thank you, I want it to last me a long time! 2002 90 Td5 Station Wagon
5th Jan 2018 3:04pm |
It's been a while since an update, today's update is the rear crossmember has been removed and the replacement clamped in place. Sills next
Click image to enlarge Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
15th Jan 2018 7:22pm |
I think the long overdue update on the RR is due to the new business taking off big time
Nice you have had a bit of time on the RR 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
15th Jan 2018 10:44pm |
Yeah busy busy!
Hopefully be able to make a bit of progress again now 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
15th Jan 2018 11:00pm |
I hope so, just didn't want all that fame neglecting the RR 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
15th Jan 2018 11:17pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4937 |
what are the bodies like to restore on these compared to the defender? My dad said that they are riveted on Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
16th Jan 2018 2:50pm |
Body's are completely different to defenders. The roof, wings and doors are the only bolt on panels - the rest is spot welded. As I replace panels I am seam welding them in to prevent moisture getting between the panels and in the box sections 2002 90 Td5 Station Wagon
16th Jan 2018 3:22pm |
LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 205 |
Great project! My Classic was probably my favourite car ever! I like your workshop, thinking of building or getting one built so I don't have to work outside anymore. Did you build yours yourself? |
17th Jan 2018 9:59pm |
Thank you
It was built by my parents friend who is a builder. (Also built their house amongst other things.) What did you want to know about it? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
17th Jan 2018 10:08pm |
Update time
Rear crossmember has been cut out and a replacement welded in. So far it's had an extremely quick dash of primer. This will be done properly when I spray the shell. The main objective was to protect it. Click image to enlarge Click image to enlarge Click image to enlarge And now for the moment of truth. Did I get it in the correct place? Click image to enlarge Phew! Yes I did. This evening I made a start on the drivers sill before running out of welding wire 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
29th Jan 2018 9:50pm |
I think that now you have made your millions, you can employ someone to run the " vent " side of things and then you can concentrate on the RR work more
BTW great bit of progress 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
29th Jan 2018 11:29pm |
