yeldef
Hi, i am trying to figure out if som rims will work for me, but don't understand it when i'am calculate it.
My current setup : 35/12.5/r16 trepadors on steel with offset 8 . I have also 2"inch old man emu hD springs.
Apparently that setup didn't work at the back of the 110 (somebody told me the back of 90 is different than a 110 ? )
I put some 30 mm spacers on and that worked, but that was a gamble...
So is my actually offset then 12 or 28 ?
I nox would like to switch my rims to beadlock rims, with the correct offset.
If I look around you have alu terrafirma who states that the ET=20 and bringing the wheel 40 mm outside, i thaught + 20 mm will bring the back of the rim closer to the springs ? so this would not fit.
hutchinson had offset 0,...will this work ? Or is a modular soft 8 beadlock with -41 the solution ?
Hopefully somebody can clarify this, at the moment its very cloudy...
anybody know how to calculate this exactly ?
thx
11th May 2017 10:22pm |
