- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
hornet
Oilpressure and Oiltemperature | |
I want to realize Oilpressure- and -temperature with additional gauges (raid). I'm thinking about using the genuine pressure-switch connection at the oilpump/filter/cooler-unit.
Did anyone realize these two values at this connection with T-and/or Y-pieces and coul take a picture of the mounting-situation?
I would like to avoid using the drain-plug solution for temperature.
11th May 2017 7:44am |
