Home > Technical > P38 Defender rear diff |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16858 |
I think you'll find that they are 3/8" BSF.
See http://www.defender2.net/forum/topic52799.html Edit - Cancel that ! It's a P38 diff of course because it's a 110. The holes are for the harmonic damper used on the P38 axle and should be a standard M12x1.75mm pitch thread. It may be that the holes need cleaning out, and it is just possible I suppose that they're not tapped. |
9th May 2017 10:26pm |
Timcat Member Since: 20 Jul 2016 Location: Tanzania at the moment Posts: 1005 |
Many thanks for the reply, definitely not M12 tried standard & fine, had two imperial bolts which were left over from the Warn winch re-build & they fitted.. god knows what they were!
10th May 2017 6:54pm |
That's wierd because M12 is the only size in the parts book for any P38 harmonic damper bracket!
At least you're sorted. |
10th May 2017 7:06pm |
Yes, another thing ticked off the list. Thanks again..
10th May 2017 10:36pm |
