Home > Puma (Tdci) > Puma Viscous Fan Part Number |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6479 |
PGG500340 is Td5 and 2.4 Puma
LR029997 is 2.2 Puma The 2.2 fan has a longer boss (the hex bit) 1988 90 Td5 NAS soft top 2015 D90 XS SW |
9th May 2017 10:20am |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 172 |
Thanks for that Martin.
So does the 2.2 Fan fit on the 2.4 and provide the same solution as fitting a spacer to the 2.4 Fan? 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
9th May 2017 10:27am |
As per Martin infos
Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
9th May 2017 2:14pm |
