Home > Td5 > Bleeding fuel filter (Td5) [solved] |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6478 |
Do it a few times. Method 2 is what has worked for me in the past, but needs repeating unless you lose the "squelching" noise of air in the fuel system. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
2nd May 2017 2:54pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Another tip, though a little late is to fill the filter up with fuel and then fit!
2nd May 2017 3:30pm |
hafman Member Since: 28 Mar 2017 Location: W Sussex Posts: 81 |
Hmmm, seems it _might_ have been a bit low on fuel. . I knew it didn't have loads in, but never thought it would be that sensitive to low quantity. Still, 20 litres has solved my problem
2nd May 2017 3:31pm |
2015 D90 XS SW |
2nd May 2017 4:42pm |
