Home > Technical > Smallest LT230 handbrake drum |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 |
Also,
I am considering shaving with a grinding disc. Are the drums liable to shatter with a bit of work applied to them? |
1st May 2017 6:43pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1728 |
Disc brake conversion? Not cheap but meant to be A1
1st May 2017 7:06pm |
I have considered but it mounts to the same point. What diameter are they compared?
Can the callipers be mounted elsewhere as the drum is right up to the rear foot well box, too mount callipers won't fit at all. A bit spendy at the mo too! |
1st May 2017 7:42pm |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
I can't think of any reason why the transmission drum brake would rub on the chassis if it's installed properly ??? What have you modified to make it rub ?
As others have said though, a disk brake conversion is a lot smaller than a drum, the calliper normally mounts at the top. http://www.yorkshireoffroadclub.net/ |
1st May 2017 8:34pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2078 |
Indeed, I can't imagine why it would rub on the chassis !
Mo The Land Rover 90 - Many are called, few are chosen. |
1st May 2017 9:04pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10359 |
I'm off this week, if you need to look at an x-eng handbrake? I put one on the 90.
Why won't it fit? His 110 isn't exactly standard. |
1st May 2017 9:33pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 906 |
Rakeway engineering do their own cable disc handbrake to fit on the back of the LT230 coupled with their own short output adaptor. I cannot find a picture but having seen one it is fairly compact. I would drop them an email.
1st May 2017 10:54pm |
Erm yes, it's not what we call an original spec Land Rover .
I'll give Neale a bell later, see if he may be able to skim some meat off the drum. He's done plenty of small bits for this over the past couple years. I have considered the shorter output housings, both Syncros and Rakeway. But trying to avoid the cost. Would mean yet another custom rear prop too! Rakeway is 70mm shorter I beleive, Syncros is 65mm. Both however do away with the speedo drive, which I have now modified to supply my dials. If not, I may just prop the 2 left wheels up and lye underneath with a grinding disc :p! With someone sat near the brakes for my H&S fulfilment . Greeni, cheers for the offer dude! I have so many reasons I need to pop to see you! Lack of time atm is my biggest downfall with everything! Hency why everything is taking so long! |
2nd May 2017 10:58am |
Spot some of the differences.
Click image to enlarge |
2nd May 2017 11:02am |
Few More :p!
Click image to enlarge Click image to enlarge Click image to enlarge |
2nd May 2017 11:06am |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 705 |
Not sure of the legalities surrounding it but could you remove the conventional handbrake altogether and use a hydraulic system that locks the normal brakes?
Is that an OM606 by the way? |
2nd May 2017 11:26am |
There's 1 or 2 legal hydraulic systems. Again, looked into it, but it's trying to keep everything a little sensible now :p!
Several mechanical systems too, plenty in fact. But just want it back on the road now. Stuff like that can come down the line. Don't "need" it in an Auto really, just for MOT and to stop defending me from screeching on the chassis and reducing vibration when running. |
2nd May 2017 11:41am |
Yes, a 606 too .
Ex. TD5. |
2nd May 2017 11:42am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16874 |
Move the crossmember?
2nd May 2017 12:24pm |
