Home > Tdi > Defender one piece door to series door conversion
shayes
United Kingdom 1998 Defender 90 300 Tdi HT Coniston Green
Morning All,
I am considering converting from a one piece door set up on the front doors, to a two piece series door conversion set. I have replaced the rear safari door with a SP 4x4 one recently and had no problems with the product or quality.
SP4x4 do the series door conversion kits and from what I have read here and on other lesser forums they seem ok.
I want to ensure that I order all the relevant parts etc ahead of this project so I am asking you guys:-
From experience, other than the basic conversion kit, what else do I need to order in.
So far above the kit I have considered foam gasket for the lock (like the one on the back door), the anti burst lock surround. I have looked at the galv. door capping that sits between the lower and upper door pieces. How does that fit?. Is there any thing else??.
Thanks guys- in anticipation...... Bow down
Post #620705 1st May 2017 9:24am
shayes
Pictures of new back door fitted Very Happy
Post #620709 1st May 2017 9:58am
SeanMcLoughlin1966
Ireland
Hello mate, lovely photos, very fond of coniston green!
Hope you get your answer soon as I am having the same problem.
Will give this thread a +Watch in the mean time.
All the best
Post #620805 1st May 2017 6:21pm
shayes
Morning guy's and Gal's,
Reading other peoples threads it appears SP doors (series conversion) have been used previously by some of you.
I am going to order these doors over the next few days and really need your help and guidance as to what to order over the basic kit. I have identified some extras ie. galv. strip that sits on top of the lower door, foam gaskets for between the lock and door, anti burst lock surrounds. Will I need any additional bits, bolts , screws ?. I also note that there appears to be a door bottom rubber seal ( on series doors) that can be bought, should I get these too.
Any help would be greatfully received,
Cheers S Smile
Post #626932 26th May 2017 7:39am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I have a set of their doors and they are great Thumbs Up
Bits you will need:
Doors
Windows
Cappings left /right (they are handed)
Each capping is held in place by 3 rivets
Anti-burst locks left/right
Barrels for the above
Gaskets for the locks
Retaining plates/screws for the locks.
Sorry the list is a bit jumbled if you look on my Jasmin rebuild thread you will see the prep I did for the doors, I Davies you do similar to make them last longer Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #626939 26th May 2017 8:27am
Harry.O
I don't have the SP doors but fitted a pair of series doors and military alloy door tops to my 90 and love them, especially with the roof off.
The SP kit looks pretty comprehensive, the doors look adapted to work with the once piece door stays which is a nice feature.
It would be worth throwing some dinitrol or similar into the frames and possibly new door hinge bolts whilst you have them apart but Mash's list seems to have everything else. Consider a bit of soundproofing for the inside, you may wish to line them also, I used plywood and carpet purely to mount speakers but will change to chequer soon because the carper holds mud.
[/img]
Post #626943 26th May 2017 8:53am
shayes
Mash, Harry O., my thanks for the above info. Have either of you fitted the door bottom rubber seal, I believe it's held on by rivits ?. Also I am sure I read somewhere on this site that the casting of the strikes is questionable. I had no problems with the one on the safari door but thought I would ask. Thanks chaps, S Very Happy
Post #626946 26th May 2017 9:19am
Harry.O
Mine used a Defender bottom seal originally which was attached to the sill rather than the door. I also fitted some felt draught excluder around the inner edge of the door top as a secondary seal and that worked well.
No issues with the strikers, mine were Britpart ones. You may wish to fit the plastic seatbelt shields to the strikers, they prevent ripping your trousers on the strikers jumping in/out and also stop the seatbelts getting chewed when the door is closed.
Post #626963 26th May 2017 10:56am
shayes
Thanks Harry for the info advice. I had heard that you can get hung up, on the strikers!, and rip your strides in the process. Best get the doors ordered up and sort out some paint. Cheers S Very Happy
Post #626998 26th May 2017 1:24pm
