Home > Td5 > Shakier as I go above 60 km/h |
kweese Member Since: 28 Apr 2015 Location: Van Posts: 62 |
Hi I recently posted thinking it was my wheel bearings or wheel balancing. It still could be. I tried driving it again today and this is what I noticed. As I increase my speed while it is "in gear" it gets very shakey after about 60km/h and more so the more I hold down the gas pedal. As I let go of the accelerator pedal it does not shake as much.
Also, if I'm going that speed and I take the car out of gear or clutch in.. it doesnt shake much. Would this eliminate Wheel bearing issues? I also notice a bit of a whining noise sometimes when I start moving the car from stop. Chris |
30th Apr 2017 4:30pm |
Could be a seized prop shaft UJ. Try removing the front prop, engaging diff lock and see if it cures it. If so, you've narrowed it down. Darren
30th Apr 2017 4:45pm |
TVR Tommy Member Since: 26 Nov 2013 Location: Bucks Posts: 179 |
Could be wheel balance and panhard bushes. Swap one of your wheels off the back on to the front. see if you get any change.
Mine had a front wheel out of balance which would start a light wobble. Then as speed increased further the play in the panhard bushes made things very shaky. New bushes and wheel swap around solved my issue. |
30th Apr 2017 5:01pm |
Are there any balancing weights on any of the drive shafts on these vehicles? A friend of mine suggested that could be an issue too.
30th Apr 2017 5:43pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1411 |
The props do have balancing weights and have to be in series. I would lean towards a seized or shot UJ rather than a lost weight, although that is possible. I think you'd be more likely to lose a wheel weight though.
30th Apr 2017 7:55pm |
Sausage fingers
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 305 |
Rule of thumb on where to start investigating when I was growing up.....
Vibrations centred around 80km/h are most likely driveshaft related. Driveshaft out of balance , phase or bent. Vibrations more pronounced around 120km/h are most like wheel related. Weights, bent rim, etc... Mind you this was for normal cars with normal/average gearing and normal wheel sizes. Patrick |
30th Apr 2017 9:55pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 898 |
Check your u-joints... 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
1st May 2017 1:13am |
My VIN Number is :
XA17------ It's a 1999 TD5. I cant figure out which part number it is, there isnt a definitive part number wherever I look. Would i be safe to assume it's TVC100010? |
2nd May 2017 1:27am |
The part numbers are different but the size is the same on all Defenders, same as RRC and DIs as well. That number works, get GKN or Timken or a good brand. Don't get Sh*^part...
Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
2nd May 2017 1:53am |
Thanks to everyone. This was exactly the problem. Resolved!
16th May 2017 5:17am |
