Home > In Car Electronics > Installing electric windows |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
A quick google will reveal you can buy electric window kits for a Defender.
Literally 2 seconds on google. http://www.paddockspares.com/defender-electric-window-kit.html Yes its easy. |
24th Apr 2017 10:54am |
cashpat Member Since: 06 Apr 2016 Location: belfast Posts: 3 |
Cheers for that. I had meant a look on the forums here. No matter, you've pointed me to the gear and I'll trust the set up is easily installed. Thanks for the help.
24th Apr 2017 10:58am |
Yup, pretty easy to do. Its quite straight forward, effectively replace manual bits with a motor. Only thing thats a tad annoying is the door cards will have a random hole from the window winder
24th Apr 2017 11:11am |
As you would imagine on an 01, random holes have become part of its make-up. More annoying than that though would be trying to find 200 quid for the pleasure of not winding myself up. Might keep an eye out for something on flea-bay while the wallet is resting. If you hear of anything cheaper then do get back.
24th Apr 2017 11:14am |
You can buy universal kits for about £50 but not as plug and play and not as neat
24th Apr 2017 12:23pm |
Don't the kits come with a plastic bung to go in the hole? |
24th Apr 2017 12:31pm |
