Home > Td5 > Engine oil - can I use my tractor oil? |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
It's your motor, use what you like .....
Technically - No. 10W viscosity is too thick at lower tempertures for the TD5 engine. Nearly all modern engines use a 5W lower rating now, some even lower [0W] The first figure is the cold viscosity rate, the last figure the hot viscosity rate, so the lower the first figure the better, the higher the last figure the better [within reason lol, 75/85W is a bit OTT] Stick to a 5W/40 [ or even better a 0W/40] Guns and Landrovers .... anything else is irrelevant. |
18th Apr 2017 10:55am |
hafman Member Since: 28 Mar 2017 Location: W Sussex Posts: 81 |
Thanks Dave; I've gone for some Castrol EDGE Titanium FST Turbo Diesel 5W-40 instead
18th Apr 2017 12:58pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2241 |
It won't harm the engine to use a 10w/40 instead of a 5w/40.
The main advantage l believe is fuel efficiency, a 5w/30 for instance will give lower friction loss in the engine and produce fractionally better MPG. Unless you are planning a road trip to Alaska then the 10w/40 will be fine. |
20th Apr 2017 7:34pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
Just to say that I wouldn't trust the Morris Lubricants product selector. Despite them offering an engine oil that was BMW approved to the correct standard and grade, it recommended something entirely different for my BMW model. Very odd. 2007 110 TDCi Station Wagon XS
20th Apr 2017 7:49pm |
Dieseljock Member Since: 03 Jun 2017 Location: Inverclyde Posts: 31 |
Mf hc plus or hc extra as it's now know is a 10/40 transmission oil with an additive package for wet brakes and clutch packs i wouldn't be using it in my td5, Mf 10/40 premium engine oil would be fine though. Ps all MF oils are supplied by morris lubricants
13th Jul 2017 9:47pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 898 |
Very specific in the owners handbook.
Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
14th Jul 2017 2:10pm |
