Home > Wheels & Tyres > Making the swap to alloys |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 |
As long as your studs have small slots or grooves cut across the ends, then yes they were designed for and will accept alloys. Being a Tdi then you should be fine - the wheels should bolt right on with the correct nuts as you have said.
17th Apr 2017 12:09am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2548 |
200Tdi vehicles we're never supplied with alloys, so you may have issues with hub drive member clearance and you won't be able to fit the alloy centre caps.
17th Apr 2017 8:38am |
okami Member Since: 06 Apr 2017 Location: Hertfordshire Posts: 90 |
Thanks guys. I'm installing Ashcraft drive members next week so I'll no longer be running stock. I'm assuming Boost and SVX rims would have the necessary clearance?
17th Apr 2017 9:37am |
Looks like I may need the spacers after all to clear the HD drive members.
My 200tdi is a very late model '93 and has rear disc brakes so I shouldn't have to worry about rim/drum interference. |
17th Apr 2017 12:11pm |
If you're changing the drive members anyway that'll likely be fine, aside from the centre cap issue as you say.
I have a 1993 110 as well, it was a right mismatch of parts. Though not sure how much of that is attributable to Land Rover and how much to previous owners. |
17th Apr 2017 3:50pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19574 |
ZU's maybe a better option without centre caps.
Just a suggestion. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
17th Apr 2017 4:03pm |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 746 |
A big for the ZU's from me. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home M0XQS |
17th Apr 2017 10:08pm |
