Home > Technical > Brakelight Switch |
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 |
behind the pedal box near your bulkhead open ended spanner, but check wires first might not be the switch, could be bad earth
14th Apr 2017 8:49am |
JamesF Member Since: 10 Nov 2016 Location: Hitchin Posts: 71 |
Thanks for taking the time to reply.. Where do I access the pedal box from.. underbeath or is it behind the master brake gubbins?
14th Apr 2017 8:58am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2078 |
Open your bonnet and stand at the offside near the hinge. In front of you you'll see the servo ( the upright circular box) and the brake master cylinder with its fluid reservoir on top. At the back of the assembly by the bulkhead you'll see a switch with 2 wires going into it. This is the brake switch 😊
Mo The Land Rover 90 - Many are called, few are chosen. |
14th Apr 2017 5:15pm |
Thanks Mo. Sorted and was a broken wire near the switch. All sorted now. Thanks again all.
16th Apr 2017 8:44am |
