Home > Technical > Oil leak detected |
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 |
Hi everyone,
Just noticed a oil drop on the floor and found oil was leaking from somewhere cv joint/ swivel seal area in the near side of the car. What could be the problem here? Should it need an urgent repair? (picture attached) Thank you everyone. https://www.defender2.net/gallery/albums/u...084219.jpg |
12th Apr 2017 8:40am |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
Could be the swivel seal assuming the swivels are not pitted or worn, Is the fluid quite thick? Jeff
12th Apr 2017 9:20am |
Hi Jeff,
Oil is not thick I recon the oil is from the diff. Thanks. |
12th Apr 2017 9:41am |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 |
This may help:
What is interesting to me is that the oil has worked its way around the swivel/axle flanges to the diff side. I'm not sure if they can fail as seals do but what about the axle/swivel gasket? Solved the bowel problem, working on the consonants... |
12th Apr 2017 1:33pm |
hi,
many thanks for the replies. As MK suggested, should i repalce the inner seal as shown in no 17 in the picture? SEAL-STUB AXLE, INNER Number Part: FTC5268 https://www.defender2.net/gallery/albums/u...0seal.jpeg |
12th Apr 2017 3:37pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2257 |
N 17 impeeds the migration of one-shot grease towards the flange. On agentmulderīs diagram is N23. What you need to check is N8 on the latter. So at the end you better replace all seals at once and to be honest none of these seals are very tight. Puma 110" SW
12th Apr 2017 4:00pm |
Hi MK,
Could you advice me any part number for the kit to purchase? Cheers. |
12th Apr 2017 4:06pm |
I belive these are all seals and gaskets for each side.
FTC3401 FTC3276 FTC3646 FTC4785 571752 Puma 110" SW ............................................................. Earth first. Other planets later |
12th Apr 2017 4:12pm |
Are they the same for single part number: Front Axle Swivel Seals and Gasket Kit STC3321?
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...SwubRXINI~ Cheers MK! |
12th Apr 2017 4:45pm |
Probably that one would do the job, but I would choose OEM quality seals (eg. Corteco) Puma 110" SW
12th Apr 2017 5:09pm |
Noted
You have been so much helpful. Cheers! |
12th Apr 2017 5:12pm |
Also hope the part number is applicable for puma models?
12th Apr 2017 5:59pm |
I would have a look first at the connection between the axle housing and the swivel bowl. Clean it and degrease it and see again. Your swivel seal is leaking too. Roel
12th Apr 2017 6:54pm |
Update : My mechanic checked it and confirmed that the bolts were too loose (pic attached) so the oil was leaking between the housing. No idea how it became loose though. Tight all the bolts and now no more oil leak!
Thanks for suggestions by everyone. https://www.defender2.net/gallery/albums/u...085110.jpg |
23rd Apr 2017 6:00pm |
