Home > Td5 > 2003 TD5 differential drain/fill plug? |
RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144 |
I'm trying to change the diff oil recently, then I discover the fill/drain plug is plastic, I'm a bit scare looking at it, since the plug is a bit deformed...
I think I will need replacement right after remove them out! May I ask if anyone knows the parts number, or alternative plug from xbay? Many Thanks |
11th Apr 2017 7:49am |
Land Rover Defender Differential Drain Plug 608246
11th Apr 2017 9:13am |
OR
Corresponds to Land Rover part TYB500120,TYB100070, TGZ500070 alternative part for 608246 |
11th Apr 2017 9:37am |
Thank you everyone, are they both fill or drain actually the same thread?
Xbay has list a set of 4 plugs for Defender, they look the same! |
11th Apr 2017 9:57am |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 705 |
The drain and fill plugs are the same on mine.
11th Apr 2017 12:14pm |
Thanks!
11th Apr 2017 2:58pm |
