Home > Wheels & Tyres > anyone running LT285/75/R16 |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1330 |
Yes me, rubs a little on the arches when cross axles but nothing major, standard suspension too
Click image to enlarge |
11th Apr 2017 7:38am |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 705 |
I have 285 75 r16s on a 16 x 8 wheels with a +10 offset. No rubbing on the arches but the back tyres do rub the edge of the spring mounts on full bump. That's with HD springs rear which give about 15mm of lift.
11th Apr 2017 11:02am |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4393 |
Yeah nearly: 285/75R16 = 32.8x11.2R16 - But who is going to quibble over .2"... |
11th Apr 2017 11:45am |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
Depends on the tyre, some are over 33" like km2 muds 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
11th Apr 2017 1:04pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2068 |
Yes. Though had to fit 30mm spacers
11th Apr 2017 2:53pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2225 |
I do. No problems at all. Comes down to the offset of your wheels.
11th Apr 2017 4:27pm |
big110 Member Since: 02 Nov 2016 Location: Sweeden Posts: 342 |
ok. whats the standard offset for stock wheels? What im looking at are 0.0 offset
11th Apr 2017 8:20pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7683 |
i have 285.75R16 BFG AT2s on boost alloys with OME 1.5" lift on a 90. no rubbing. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
11th Apr 2017 8:28pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
I'm running 285's on Matt Lee's. Offset is just right for the tire. Does anyone know what the offset on the Matt Lee's is? it's a Landrover thing...
my renovation thread: http://www.defender2.net/forum/topic40792.html |
12th Apr 2017 4:28pm |
I don't know whether there was a 'standard' specification for them. I think they were often manufactured toclient specifications? Mine are 0 offset
12th Apr 2017 4:59pm |
diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260 |
30mm spacers, no rubbing at all. BFG KO2s are only 275mm wide though. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
12th Apr 2017 7:45pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
285/75 STT PRO's on RVS Semi-Beadlocks with et10. Have had to widen turn circle so could do with 20-30mm spacers to get the better turning circle back.
13th Apr 2017 11:53am |
