- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
ami1971
Replacement fuel line for v8 | |
Looking to replace fuel from carb to tank on an 1987v8 , what's best to use please 8mm plastic pipe or steel also will need ends which go to the inline metal filter under seat, Ebay best to buy 8mm pipe?
9th Apr 2017 10:26pm |
montyjn
I've just had this done on my v8 110. We used a mixture of nylon hose and copper piping. I think the internal diameter was 6-8mm (can't remember). The fuel tank also ended up being dropped as the pipes near the top were knackered. Get the impression it is not a fun or easy job..
12th Apr 2017 9:15am |
