Home > Td5 > Stuck Fuel Filler Cap! |
When mine did that it required drilling 2002 90 Td5 Station Wagon
9th Apr 2017 3:12pm |
kyvlle Member Since: 22 Jul 2016 Location: Essex Posts: 55 |
Right. I'm ordering a new fuel cap.
Going to see how I can drill or prise the old cap off! |
9th Apr 2017 3:33pm |
Try graphite powder in the key slot work it in with the key manage to get one this way
9th Apr 2017 3:48pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Mine does this every now and then, i find if you pull the cap up while turning, eventualy it gives in!
I will probaly find myself stuck on a forecourt one day not being able to fill it up? Must get a new one too.... 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
9th Apr 2017 5:14pm |
Crisis averted for today at least! I managed to to unscrew the filler cap after pulling up at an angle while turning. The "at an angle" bit is important, it's as if I was trying to pry the cap off -- that got the internals to latch -- and allowed me to unscrew the cap.
When putting it back, one click is fine; two clicks and it's back to being stuck... Hopefully I can pry it off again when the new cap arrives in the post in a couple of days! |
9th Apr 2017 8:33pm |
TechnoTurkey Member Since: 25 Jul 2016 Location: Worcestershire Posts: 88 |
If you drill then remove the filler pipe from underneath first, stops any debris entering the tank.
11th Apr 2017 2:50pm |
