Home > Technical > Td5 injectors |
As far as i can tell Bosch made the original injectors for my td5. I have been advised that I may need one or more of my injectors refurbing (as it sounds to be dragging apparently) so my plan was to buy a new set and replace them and if I ever have the same problem I can get my originals refurbed and always have a spare set.i need my motor most days so taking them out and sending them off won't really work, so on to my question. I've seen some new injectors for sale from intermotor that are advertised for my year defender, so does anyone know if these are a good quality make and they should be fine or if I should avoid?
Any opinions welcome Cheers Ray Ray My build thread http://www.defender2.net/forum/topic17615.html |
6th Apr 2017 8:31pm |
Ah, ok thanks for that what did you end up doing? Did you find new Bosch ones or have yours refurbed? Ray
6th Apr 2017 11:03pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 539 |
I believe the injectors in a Td5 are made by Delphi.
Regards Will 2005 90 XS 1954 86'' Series 1 tilt |
7th Apr 2017 8:57am |
Sorry yes they are Delphi, don't know where I got Bosch from Ray
7th Apr 2017 8:59am |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4393 |
There are some reconditioning firms around that might be worth investigating, like United Diesel etc.
Anyone got any experiences with recon injectors? |
7th Apr 2017 11:58am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
^^^ I get quite a few done by PowerDrive in Portsmouth, most recent were a set for a Nissan Cabstar,
Not cheap at just over £600 for the 4 but much cheaper than new units. Sometimes the prices quoted for new ones by different Dealers are simply not an option, I've always had them refurbished and never had issues. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
7th Apr 2017 1:14pm |
Asked for a quote, see what they come back with.
7th Apr 2017 3:14pm |
Super quick reply to my email;
7th Apr 2017 4:33pm |
They are great to deal with, and their work has always been spot on
They have just done a Ford Cargo fuel pump, which was perfect. We are a good hour from them and their salesman "Merv" is first class, he came up from Southsea to Newbury at the drop of a hat to collect some injectors, 2 days later they were back on my bench! We do have local injector specialist but I choose to use PowerDrive simply down to their outstanding service. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
7th Apr 2017 5:05pm |
