Home > Wheels & Tyres > Hutchinson Offset/wheel Question |
Depends on the size of tyre you plan to fit rather than just the wheel. Darren
5th Apr 2017 10:11pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7681 |
The 8j would allow for a wider stance as they will take wider tyres Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
6th Apr 2017 7:47am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
We are running 255/85/16 BFG M/T on Hutchinson beadlockers on a 90 with standard suspension set up.
Can not remember offset but think it is 0 Suggest you contact Nakatanenga for advice. Brendan |
6th Apr 2017 9:46am |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 |
8j sold out!
7J can be used with the usual tire sizes up to 255/85 without lift. WANTED: SII or SIII in max 1.5k |
6th Apr 2017 12:39pm |
Wider rims take wider tyres as above, if you want wide stance get wide rims. If you want diff height clearance then fit same width to narrower rim. Cheers
6th Apr 2017 2:36pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2224 |
I have 16x9 0 offset with 285 75 16 fitted to a completely standard 110... No issues.
6th Apr 2017 2:47pm |
big110 Member Since: 02 Nov 2016 Location: Sweeden Posts: 342 |
thx all for the assist.
6th Apr 2017 11:43pm |
