Home > Td5 > Central locking issue - 110 n/s/r door |
It's likely to be either wear or resistance in the linkage or the lock itself. As a first step, I'd give the lock a good blast of your favourite aerosol lubricant, work it in a bit and see if that cures it. Darren
5th Apr 2017 1:13pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1327 |
Thank you, I did do that prior to building the door car back up, ill see if lubing up the door lock pin helps.
5th Apr 2017 2:47pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
Have a look at http://www.defender2.net/forum/topic52876.html My problem was on a front door but the mechanisms are similar.
John |
5th Apr 2017 3:29pm |
Thanks John, that looks about right what I need, is that just a bit of elastic rope, trying to think where I can get some from.
5th Apr 2017 3:58pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2159 |
Make sure that the actuator is adjusted properly.
So that the solenoid can operate through its full range when locking/unlocking. |
6th Apr 2017 8:53pm |
