Home > In Car Electronics > Wiring Electrically Heated Seats. |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 |
Yes, FCX sell a kit, http://www.fcx.co.uk/_p/prd1/2620831381/product/heated-seat-loom My 90 Project : http://www.defender2.net/forum/topic52774.html
5th Apr 2017 4:32pm |
Woodruffsdad Member Since: 16 Feb 2017 Location: Gloucestershire Posts: 29 |
Thank you very much. Looks good! 2005 Defender 110 Td5 Special Vehicles Station Wagon Zambezi Silver With Black Roof And Black Wheel Arches/Eyebrows.
5th Apr 2017 4:48pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19578 |
It is the FCX kit that I have. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
5th Apr 2017 6:57pm |
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 |
You only need the switches two fuses and some 2mm thin walled cable, fused live to switch then from switch to seat, earth from seat to body.
No relay needed, not timer if Genuine seats as they have a heat cut off |
5th Apr 2017 9:44pm |
2005 Defender 110 Td5 Special Vehicles Station Wagon Zambezi Silver With Black Roof And Black Wheel Arches/Eyebrows. |
5th Apr 2017 11:51pm |
5th Apr 2017 11:52pm |
HeX Member Since: 10 Jun 2014 Location: Home Posts: 4 |
Hi,
I just bought some used original heated seats from a Defender which I wanted to wire up. It's going into a Ninety so I wanted to go for the universal type of switches of this type: Click image to enlarge Now this offers the possibility of having 2 levels. The original wiring has the seat and the back connected in series. So I thought of making level 2 in parallel and level one in series. Question is, will the heat elements manage the parallel connection and not overheat? Any experience? |
18th Apr 2017 3:51pm |
HeX
might be worth looking at the kit Exmoor Trim sell, that should allow you to connect it all up and use those switches, which is what I have fitted. My 90 Project : http://www.defender2.net/forum/topic52774.html |
18th Apr 2017 4:40pm |
Thanks but the seats I've bough already have the heating installed. So I just wonder if I can use them they way I intended without damaging them.
18th Apr 2017 4:42pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7687 |
consider options on ebay from Weaco, they sell sets for around 20 for one seat with all the wiring, scrap their pads and use their wiring kit. in fact their pads are good to. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
18th Apr 2017 6:40pm |
I use the Genuine switches the FCX kit with Waeco pads.
Never seen the need to use the warm up, I've used it before and it heats fast and then you have to change over. The constant setting is more than adequate and heats up just as quick. So I just use single pole switchng fir constant heat using Genuine switches. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
18th Apr 2017 8:25pm |
@ custom90steve Yes that is probably what I'm gonna end up doing. Genuine switches won't fit the style though. They would look strange in a 1989 Ninety with no other switch looking like that
@jst I know there are all kinds of sets i can buy but I was trying to find out if somebody had tried connecting them in parallel and if they would manage with direct 12V supply to each element. I'm not interested tearing my perfect seats apart yet |
19th Apr 2017 7:36am |
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 |
mobilecentre also make a couple of wiring sets with different switches
19th Apr 2017 9:12pm |
V8Smith Member Since: 18 Apr 2017 Location: Cuckfield Posts: 22 |
Ive seen the wires and switches from Mobilecentre, anyone know if they are any good?
12th May 2017 2:53pm |
