Home > Technical > TD5 low range switch. |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 719 |
If I remember correctly this switch dampens the throttle response in low range to avoid rapid changes of engine speed. Useful when bouncing over ruts or tricky terrain and for when you are wearing wellies.
Don't know what would happen ecu wise if you disconnect it, but your throttle response may be too extreme for off roading and become unsafe. |
24th Mar 2017 9:38am |
