Home > Td5 > Fuel filter housing replacement |
EWS Member Since: 29 Nov 2011 Location: Bristol Posts: 156 |
Hi all.
I need to replace the housing as it fractured around the bolt holes,seems to a be common problem. I plan to use a replacement made by GORE http://goreproducts.com/products/td5-fuel-filter-housing . Am i correct in that all i have to do is transfer the connections from the old to the new, or is it advisable to replace the air bleed/non return valves, L/R or after market, any to avoid . Any trick to remove the hoses from the fittings. Edward |
23rd Mar 2017 11:16pm |
Looks like you got to that just in time Ray
31st Mar 2017 10:49pm |
