Home > Maintenance & Modifications > Parking sensors |
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 616 |
Fitted.
Click image to enlarge V8 90...WIP |
9th Apr 2017 6:34pm |
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 253 |
Park Assist set up taken off a Discovery 2 and fitted into a modified rear step .
No issues as yet with fitting the sensors into a metal housing but the sensors do have a plastic casing. Click image to enlarge Click image to enlarge |
9th Apr 2017 8:37pm |
Other than perhaps with cheap kits the cutter they supply isn't able to drill metal, i can't see why you couldn't fit them in metal.
The circle you see on the sensors is the plastic/foam insulator, the middle bit is the actual echo sounder. The outer bit is literally just there to hold it in the hole. |
9th Apr 2017 9:41pm |
