Home > Tdi > New exhaust |
ChrisWoods Member Since: 29 Dec 2016 Location: Spreyton Posts: 164 |
Straight through will be fairly noisy but getting rid of the mid box keeps the noise to a sensible level. I'd imagine there's only 5 hp to gain from an exhaust on a lumpy diesel truck. Stainless is must though. I think de cat pipes let the engine breath a bit better but depends how strict your MOT tester is. 2009 2.4TDCi XS Utility Wagon.
23rd Mar 2017 9:28pm |
There won't be a cat on a 200tdi. Darren
23rd Mar 2017 9:54pm |
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 |
The 1994/5 300tdi"s wern"t Cats either,
23rd Mar 2017 11:28pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Go for a genuine or Bosal exhaust system.
Can probably replace the whole system for under £150 delivered compared to the cost of a Stainless setup. I have done my downpipe at the front once shortly after I bought it due to it having a hole in it and my rear box 3 times in the 6 years I have owned my truck and still spent less than the cost a stainless system. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
24th Mar 2017 1:27pm |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
Yep, I was talking about the silencers
Which companies manufacture a system without the mid box?
3 times in 6 years is pretty bad? |
24th Mar 2017 7:48pm |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
My 300 tdi, has a mild steel down pipe, straight through centre ie in stainless, no one seems to make them in mild steel, a d a cheap as chips rear section. Replaced approx every 26 months, only cost about £25 each. Seems to work for me, a stainless tail pipe is a lot of money .
25th Mar 2017 7:26am |
Where did you get the stainless center section from?
25th Mar 2017 11:04am |
can't remember, maybe paddocks, T'is a 110 I should have said. no too noisy at all
25th Mar 2017 3:48pm |
Its the rear section that suffers most, the 3 I have replaced comes to £60 over 6 years and a grand total of 2 hours.
Given the cost of stainless system I'd say my time and money have been well spent Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
27th Mar 2017 11:42am |
