Home > Wheels & Tyres > Offset question |
On the boosts your et was 33 so with the spacers will be 3 as you said.
The sawtooths alone would be 17 mm further in to the arch than the boosts and spacers and with the spacers they would be 13mm further out than the boosts and spacers Ray My build thread http://www.defender2.net/forum/topic17615.html |
20th Mar 2017 10:28pm |
Sorry just re read about the tyres. The 265s are 30mm wider overall so you would expect an extra 15mm inwards of tyre and 15mm extra outwards of tyre on top of the measurements of the wheel so as you said.
Tyre 2mm further in without spacers Tyre 28mm further out with spacers Ray My build thread http://www.defender2.net/forum/topic17615.html |
20th Mar 2017 10:33pm |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 804 |
So, therefore with the extra thickness of the 265s, the sidewall of the tyre would be 15mm on top of that equation. 2002 110 td5
20th Mar 2017 10:35pm |
Cheers Ray, I thought that was the case. Looks like I can get rid of the spacers then! 2002 110 td5
20th Mar 2017 10:38pm |
Yep could do when I finish spending money on everything else I think I'm going for 18" sawtooths on mine Ray
20th Mar 2017 10:41pm |
