Home > Td5 > TD52003 back seat broken |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6480 |
Yes, Land Rover. Part number ACC710320 1988 90 Td5 NAS soft top
2015 D90 XS SW |
20th Mar 2017 12:26pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 539 |
I replaced mine a few years ago and they have cracked again, I thought about buying some 5mm acrylic and making my own. The price of the new genuine ones have gone up a lot as well!
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt |
20th Mar 2017 10:17pm |
I'd make your own out of ply wood. Ray
20th Mar 2017 11:35pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2238 |
Land Rover have biffed up the prices of a lot of spare parts.
For instance the rev counter has gone up from £85 to £300. |
24th Mar 2017 11:01pm |
Bearders Member Since: 10 Jan 2013 Location: West Midlands Posts: 9 |
I recovered all 4 rear seats 18 months ago and the mount points were broken on every base.
Seems LR changed from hardboard to plastic around TD5's, plastic are hugely more expensive so I went for hardboard, although the mount point for the rubber leg stopper was in a different place. Have lasted so far but expensive for a bit of painted hardboard. Other option I thought of was using black phenolic sheet, a substitute for tufnol. 400mm x 600mm x 4mm sheets available on eBay for just under £20 each and should be hugely stronger than original but would need length trimming and holes drilled (was planning to use best old one as a template) |
28th Mar 2017 5:53pm |
