Home > Tdi > Fuel injection pump banjo bolt washers (200 TDI)
mini Anaconda
The fuel inlet banjo bolt on the injection pump seems to have started to leak a little. Could someone please confirm the part number for the copper washers, I have done a bit of research and the number seems to be ERR894, does that sound about right?
Could this also cause a slightly lumpy/erratic tick over?
Many thanks.
Post #610327 18th Mar 2017 6:12pm
dorsetsmith
that banjo bolt also used on the turbo oil feed and copper washer part number is FRC 4808
Post #610333 18th Mar 2017 6:46pm
mini Anaconda
I took your advice and pleased to say they fit perfectly and solved the problem, many thanks.
Post #612932 28th Mar 2017 8:56pm
