Home > Technical > help! more headlight issues! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19569 |
I sympathise, I really do. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
17th Mar 2017 10:09pm |
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 |
Whether the failure is, it is connected to all of the lights. Left and Right Headlights are on separate fuses so take a look at the wiring diagram and find the common failure point.
Is it blowing fuses or just not working? As a temp solution hook up a cheap set of fogs to a switch but not using any of the Land Rover wiring. They can be a get to work/home until you can fix it properly. This may not be legal way to drive, it isn't any worse than other car users on the road these days. |
18th Mar 2017 6:58pm |
Miggit Member Since: 09 Mar 2017 Location: Milton Keynes Posts: 72 |
It's highly unlikely that 4 separate circuits have failed simultaneously, it's more likely to be the 2 most common things... the earth or the fact that it's made by Land Rover and you got it wet... afterall they are trying to follow in the tradition that they gained with Lucas components.. they must spend days try to find components of equally poor quality
And I don't know why I'm laughing... my car is riddled with Lucas parts...D'OH! RRC 2.4 TD... it's either a stretched 90 or shrunken 110!! ML 270CDI |
18th Mar 2017 8:34pm |
monk Member Since: 02 Mar 2017 Location: east yorkshire Posts: 39 |
Right! Basically i gave up, id had enough and called an auto electrician, if this makes any sense to anyone, the live feed back to the switch had failed somewhere he couldnt find where he said it would be a pain to find but said it would be a large connector block probably and a bad connection so just fed the live from somewhere else and chopped the old feed off!
19th Mar 2017 8:37pm |
Chopped the old feed off. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
19th Mar 2017 8:55pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 719 |
Glad you got it sorted and hope it wasn't too expensive
The joys of Defender ownership. |
19th Mar 2017 9:09pm |
60quid! But i must have spent 4+ hours trying to find it, i know the guy who fixed it until yesterday couldnt get his number, know hes been an auto spark 25+ years so he knows what hes doing!
20th Mar 2017 12:13am |
