Home > Maintenance & Modifications > EGR after remap to blank or not to blank |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
Blank it off but keep the gubbins that come off just incase they change the rules.
16th Mar 2017 1:58pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
You don't have to take anything off.
You put a blanking plate after the egr cooler just before the egr valve itself. Takes about a half a hour to fit |
16th Mar 2017 5:23pm |
proloFort Member Since: 16 Mar 2017 Location: Montereau Posts: 248 |
Hello I must doing also this job. I think on the weekend. I am looking for tipping for this job. Is there some conversations on this job. My english stops the searching tool to work well
I am deciding that to do off the hood is a good option and to sit me on the engine to undo the lowest bolt. I cannot reach from under. Lo |
16th Mar 2017 7:40pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16879 |
I've been running a BAS no-egr map for getting on for 7 seven years and 150,000 miles and did nothing to the EGR, I simply left it alone. It is unlikely that it would work properly after 7 years of inactivity, but since I have no intention of reverting to the original map I don't see it matters. I have never had any problems with my inert EGR.
16th Mar 2017 7:50pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3613 |
it is a simple blanking plate that slides in, if you put EGR blank into EBAY they are a couple of pounds DEFENDER 90 TDCI XS,
16th Mar 2017 7:58pm |
Blank it off, as you don't know for sure that the EGR is fully closed, it might be stuck partially open.
I was tempted to blank mine and remove it all to declutter the engine bay, but as Bankz5152 says, they might change the rules in the same way they have for Catalytic converters - ie a visual check to see if the EGR has been removed. |
16th Mar 2017 9:14pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7687 |
does anyone have a picture of where the blanking plate goes?
Doe those allen bolts come undone easily normally or does it become an issue? Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
17th Mar 2017 10:27am |
Hello,
I see lots of times BAS. What is BAS please? Thank you Lo |
17th Mar 2017 10:30am |
^^ BAS = Bell Auto Services https://bellautoservices.co.uk/
Run by Pete Bell, creator of remaps and other high-quality engineering upgrades for Landrover vehicles. Provided that the EGR is currently closing properly, there really is no need to blank it off when upgrading to a no-EGR map. |
17th Mar 2017 10:49am |
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 |
Quick question, if blanking with a BAS remap, is it the 'fully blanked' plate I should be fitting, as apposed to the plate with a small centre hole. Thanks
18th Mar 2017 12:39pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19577 |
Full blank. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
18th Mar 2017 12:57pm |
Thank you Steve.
18th Mar 2017 9:10pm |
Dean Watson Member Since: 17 Jul 2011 Location: Derby Posts: 254 |
does anyone have a pic of where to fit?
Dean |
21st Mar 2017 1:32pm |
This thread maybe of help and interest:
http://www.defender2.net/forum/topic5673-30.html Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
21st Mar 2017 2:36pm |
