Home > Td5 > oil in ECU plug, questions please |
Unless it's a really bad case I wouldn't worry about oil inside the ecu, especially if the defender seems to be running fine. As you said replace the injector loom and clean the red plug out regularly with electrical contact cleaner and you'll probably find it more power returning when it's all clean.
Edit: only go for an oem or genuine injector loom and I sealed mine and haven't had oil in the red plug since. I put a thread up with some pics on here somewhere if you fancy hunting it out. Ray My build thread http://www.defender2.net/forum/topic17615.html |
15th Mar 2017 9:03pm |
bogwert Member Since: 03 Sep 2016 Location: Dundee Posts: 194 |
16th Mar 2017 11:44am |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 898 |
Be sure to re-seal the ECU cover when you put it back on with some silicone or other sealant. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
16th Mar 2017 2:39pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 572 |
Oil is not a real problem. Real problem are tiny pins in injector connectors, high temperature of these and high current used for controlling of the injectors (approx.. 80A)
Just clean the connector with a break cleaner without acetone and let it dry. You can also replace o-ring on the injector loom connector on the input od loom into the engine head. Sealing the top lid of ECU is nice idea - use some neutral sealant. And look on those 4mm holes in the bottom lid of ECU. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
16th Mar 2017 9:50pm |
