Home > Td5 > Engine Fault |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 666 |
I had similar symptoms in my 2005 TD5, it turned out to be one of the relays under the drivers seat
Good luck |
12th Mar 2017 6:43pm |
1. Oil red ecu plug
2. relay under driver seat 3. earthing battery to chassis and to transfer box also C0556 ecu earth in driver seat box Click image to enlarge |
12th Mar 2017 6:47pm |
mpald Member Since: 16 Dec 2016 Location: North East Posts: 40 |
Thank you for your suggestions; it was an earthing issue to the chassis. Now sorted.
18th Mar 2017 2:45pm |
