Home > Technical > Bulkhead/Windscreen Bracket |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 985 |
I had the same problem after 14 months. After much debate, I just went for the Gore replacements. By the time I've messed about with the dealer my time is worth more than the £90.
On a grey Defender with Black Pack, having black windscreen brackets looks really good too. Just wish they'd hurry up with their replacement door hinges. |
15th Mar 2017 10:03am |
Maybe I won't be buying after all! I'll just revert to plan A of converting the bolts to security bolts with some metal putty. |
20th Mar 2017 10:24am |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2260 |
In my opinion its galvonic induced corrosion .....the aluminium bracket is small (anode)and is atttached at one end to a aluminium windscreen frame and at the other to a large steel bulkhead(cathide),the bracket is being sacrificed especially where the ali bracket is attached to the bulkhead. It does not help that the original gasket is posh cardboard allowing moisture to aod conductivity across it. You need to use some anti galvonic paste such as moly ceremac or the like .....it doesnt matter how well the bracket its painted and it helps if you paint the bottom surface of the bracket ,but if you dont block the moisture it will corrode eventually .Most appear to corrode even in the pre ford days when they used to paint them properly. |
23rd Mar 2017 2:33am |
myonehere Member Since: 03 Mar 2009 Location: Worcester uk Posts: 153 |
HELP..
I have this corrosion problem on my 2 -year - old Defender. I had it on my 2013 version - and they fixed them under warranty, no problem. This time, however ,they INSIST that the problem is a ''stone chip'' and REFUSE to do anything about it. When, quite clearly, the bracket is corroding under the existing paint. They also add that " as there have been modifications" this also obligates them from any rectification. Pardon?. Modifications are minor and do not involve anything around that area. |
12th Oct 2017 4:46pm |
Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 216 |
Hi myonehere,
Take a look at the Puma topic, and sockpuppets thread on 'how long to fix'. I have the same problem, but my dealer couldn't be more helpful today. Contact LR customer relations. Each LR garage is obviously different with regard to customer relations, and if it's the Droitwich dealer, loads of moans on this site about them, Best of luck with getting it sorted, Cheers Andy |
12th Oct 2017 5:11pm |
thanks for that .. this is Stratstone Cheltenham who, in the past, have been very helpful -but now truly hopeless.
I have now put it with LR customer relations. Last edited by myonehere on 12th Oct 2017 6:12pm. Edited 1 time in total |
12th Oct 2017 5:33pm |
Look at the thread ' landrover customer relations' in the Defender section. There is a member on there who works for them, they are 'CRC@landrover',
Cheers Andy |
12th Oct 2017 5:46pm |
Yes - done it now, thanks
12th Oct 2017 6:12pm |
