Home > Tdi > Slave cylinder on 300tdi
Kst80
I need a new slave cylinder, looking on here I see genuine parts appear best chioce and I have ordered one from ny local Land Rover dealer (in stock and cheaper than my limited search)
My question is that my searches revealed two types depending on gearbox serial number (mine is the older type) however the dealership tell me there is only one for the 300tdi and the other one is for the TD5.
Are they correct or am I going to be disappointed when I try to fit it, possibly?
Thanks Kev.
Post #608389 10th Mar 2017 4:13pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Depending what's wrong with it, assuming its a split boot you can buy a rebuild kit for them.
300tdi slave cylinder : FTC5202
Repair kit : STC2818 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #608393 10th Mar 2017 4:33pm
Kst80
I looked at the kits but need it doing ASAP for a trip so thought I would just swap it and later maybe sort the old one for next time.
The part number I found was FTC5072, the FTC5202 is for the higher serial numbers....I think, this is what is confusing me.
Cheers.
Post #608396 10th Mar 2017 4:50pm
Mash
Mine is a 98, the only difference I have seen is pushrods part numbers. Worst case of getting from a main dealer would be get both on a use or return and compare the two with your old one, take the unused one back and get the cash. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #608423 10th Mar 2017 6:17pm
Kst80
Sounds like a plan, cheers Mash
Post #608461 10th Mar 2017 8:23pm
