Home > Puma (Tdci) > 8 Years a Puma owner. |
That's impressive, considering they don't have a cam belt. |
10th Mar 2017 1:04pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 640 |
So that equates to around 3300 miles a year?
Not even run in yet! |
10th Mar 2017 1:56pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19553 |
Mines on 56k and approaching its tenth birthday.
Brakepads, clutch, Waterpump, tyre's, EGR. Not too much else. If you want more Torque the Alive stage 1 is the way to go. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 Last edited by custom90 on 16th Mar 2017 12:21pm. Edited 1 time in total |
10th Mar 2017 2:12pm |
Crofter Member Since: 19 Feb 2015 Location: Peterhead Posts: 169 |
Got to be honest mine has done just under 40,000 I bought it new in July 2009. Most of that miles was country use checking sheep etc. I read about the cam belt not being replaced, what is the interval for replacement? I have retired now I am keeping the landy as I like it and it tows the caravan. |
16th Mar 2017 12:15pm |
Don't you mean the accessory drive belt? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
16th Mar 2017 12:22pm |
The fan belt (aka Aux Drive Belt) has a 10 year change interval, but it doesn't hurt to change it sooner. Genuine belts aren't expensive. It's a simple job to change them, just takes a little patience.
None of the Puma engines have a Cam Belt though, they're all chain driven, which should in theory last the life of the engine. |
16th Mar 2017 1:15pm |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 |
FYI:
Pretty much any quality stage 1 remap = more torque at lower rpm Solved the bowel problem, working on the consonants... |
16th Mar 2017 1:28pm |
Thanks foe the answer regarding the belt drive. I used to have a Discovery and was recommended to change at 70,000 orif it was used say on farm 35000. But anyway you have answered my question so I can sleep peacefully.
17th Mar 2017 10:38am |
