Home > Td5 > TD5 Turbo Actuator Pipe |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 430 |
Does anyone know the code or part number for the TD5 turbo actuator pipe, the 8mm or 10mm pipe that goes to the actuator. Mine is split, old and tired and I need a new one.
Help! Can get access to the Russian parts catalog, link doesn't work ! http://lrparts.ru/ Tank |
10th Mar 2017 12:47am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
http://new.lrcat.com/#!/1228/13789/17286/1358/17612
Although that looks like it has the control solenoid of the discovery? Silicon replacement may be an option? |
10th Mar 2017 1:06am |
Thanks Miker
A silicone one would be nice, wonder where I could get a blue one |
10th Mar 2017 1:18am |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4401 |
Hi.
Mine melted on the turbo whilst travelling through Spain. Quite the task to find a replacement in the middle of nowhere back country.. Good fun You can replace this pipe with a length of fuel pipe. It is always strengthened and works a treat plus you can get it from any motor factors. Couple of small jubilee clips and you are good to go. |
10th Mar 2017 7:43am |
Thanks guy.
Tank |
10th Mar 2017 7:51am |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 539 |
Tank,
I have recently replaced the pipe on my dads Td5 Discovery and it is just 4mm internal diameter pipe just do a search on ebay for 4mm silicone and loads come up in all different colours. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt |
10th Mar 2017 1:34pm |
Just make sure the pipe is strengthened internally (laminated) if not you risk collapse or over inflation when on boost...
10th Mar 2017 3:35pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
Its an actuator pipe. Not a boost pipe.
13th Mar 2017 11:52am |
