Home > Puma (Tdci) > Weird problem with lights and alarm |
The grey plug for the tow socket is usually behind the plastic protective cover underneath the drivers side rear wheel arch. It's above the cross member and basically behind the panel where the lights are bolted. Ray
6th Mar 2017 7:13pm |
You're right, you've eliminated the trailer socket as the cause.
It is still classic symptoms of a bad (ie loose or dirty) earth connection, it's unlikely to be a chaffed wire. |
7th Mar 2017 8:18pm |
OleDave Member Since: 19 Oct 2013 Location: CARDIFF Posts: 175 |
Hi zsdpuma, I hope your correct as if it is it should be an easy fix for an auto electrician, sadly with my age and athritic condition I can no longer crawl underneath it to check all the earth straps so have to depend on others now, the problem has stupidly put all our plans in the air and me completly out of sync until its sorted, we were looking forward to getting away with the caravan soon so I hope the news is good news on Friday morning after they have had a look at it, when I worked in a garage in South Wales they used a local company, Andrew the owner is a whizz with electrics so I am comforted by the fact he will be involved. Will let you all know the outcome and the reason for the problem.
Regards Ole Dave |
8th Mar 2017 8:32am |
Hi Guys, well collected my lovely Landy this afternoon from the auto electrician guys and all working, the problem was as quite a few of you mentioned that being an earth problem, but it was a specific earth problem relating only to the rear section of the vehicle which is for all the lights and hitch connections, not being Defender specialists they decided rather than spend hours looking for that specific location they would run another new earth which cured the fault.
My question to you all is, does anybody know where that specific earth point is as I would like to root around and repair it, their guess is that it has corroded and possibly snapped? would be very happy if someone knows exactly where it is and can point it out to me, my suspicion is its up under the RH wheel arch behind possibly the plastic flap but I am only guessing? Regards to all Many Thanks Ole Dave |
10th Mar 2017 4:31pm |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 |
Click image to enlarge Note: this is for the 1999 TD5, but I guess it could very well be the same for the Puma. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
10th Mar 2017 4:50pm |
I would guess most of them are the same.
RH rear wheel arch would be my first port of call on that list. |
10th Mar 2017 5:32pm |
Thank you chaps, will on a dry day take the wheel arch liner off and have a good look, I knew you guys would know see! wonderful thank you all so much.
Ole Dave |
10th Mar 2017 6:00pm |
Going by the pic it's probably on the inside of the chassis rail.
10th Mar 2017 6:09pm |
Click image to enlarge Last edited by dorsetsmith on 10th Mar 2017 6:32pm. Edited 2 times in total |
10th Mar 2017 6:16pm |
The earth eyelets ends your look C1412-1 / C1413-1 and C0557-1 / C0558-1
10th Mar 2017 6:17pm |
