Home > Td5 > TD5 Turbo |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
If you fit a hybrid you'll have to have it remapped to get the most out of the new turbo. Fine with a snorkel they just restrict air flow. Open up your airbox and remove the impeller, should help the air flow better
[URL=][/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
1st Mar 2017 12:27pm |
I agree on the impeller but I don't think that the part you cut out is the biggest restriction. In front off the pedal box is a water seperator that is not even 65mm internal diameter while the part you cut out is almost 80mm. Roel
1st Mar 2017 6:58pm |
True! Just a quick pic i grabbed off google, remove the lot for max air flow. You can see in the photo the impeller is missing
1st Mar 2017 10:02pm |
